SRAM has announced their most budget-friendly Guide brakeset yet.
Guide T brings the consistent performance that you have come to expect from our lightweight Guide four-piston caliper. Pair this with MatchMaker for a clean looking bar set-up, plus the ease of use with our Bleeding Edge drip-free bleed port and you have a smart budget minded brake that keeps you in control.
Features
- Lightweight 4-piston dual-diameter caliper
- MatchMaker compatible
- Featuring the World Championship-winning S4 caliper with Bleeding Edge™ and Heat Shield technologies
- Ambidextrous lever mount
Specifications
Weight: 280g (Direct Mount, 800mm hose)
Lever Material: Aluminum – Stamped
Caliper Design: Lightweight 4-piston dual-diameter caliper
Finish: Gloss Black
Rotor: 1-piece CenterLine
Pad: Steel-backed organic
Price: $105
Tags: sram, SRAM Guide
