Schwalbe release Tire Booster for easier tubeless assembly
By Press Office · 45 comments
With the new Tire Booster from Schwalbe, tubeless tyre assembly can be accomplished easily. The light, handy cylinder can be used both statically and on the road.
ccs-62657-0-03082700-1477319308.jpgThe Schwalbe Tire Booster in use at the Enduro World Series in Finale Ligure.
A powerful blast of air is required for tubeless tyre assembly so that the tyre bead quickly presses into the rim flange and the tyre is sealed. “Depending on the combination of tyre and rim, it doesn’t always work with conventional floor pumps,” explains Peter Krischio, Schwalbe Product Manager Race. In the professional workshop or at the garage, a compressor helps out.
For safe and easy fitting without a compressor, Schwalbe is now launching the Tire Booster, which was developed in collaboration with the British start-up Airshot. With it, a pressure of up to eleven bar can be immediately applied in the tyres. “The tyre immediately seats itself safely on the rim and seals everything evenly,” says Peter Krischio. “The Tire Booster is a significant advantage for assembly of tubeless tyres. At a light 435 grams, you can easily take it along on your trips.”
ccs-62657-0-52544800-1477319307.jpgThe Schwalbe Tire Booster makes tubeless tyre assembly easier.
If you need an even bigger flow of air, a special adapter is also available. For this, the valve insert is removed and the adapter is screwed directly onto the valve spindle – the airflow is thus maximised.
And this is how it works: connect the Tire Booster to a conventional floor pump using the SV valve on the Tire Booster, fill the cylinder and then operate the quick-release valve. The air immediately distributes itself evenly and the tire seats itself – usually with the typical loud crack – firmly on the rim.
The Schwalbe Tire Booster will be available from December 2016 from specialist bicycle retailers for 59.90 EUR.
Shebeen
Oct 24, 2016, 2:34 PM
so it's like the coke bottle version, but with CE stamps of approval?
that product testing must have been fun.
MrJacques
Oct 24, 2016, 2:35 PM
Similar idea to that Topeak pump, but at a better price. Nice!
BDF
Oct 24, 2016, 2:37 PM
My Ryder pump is also similar. Have seated up to 2.35 650B with it no problem.
Fisan
Oct 24, 2016, 2:42 PM
Can I use it to clean my laptop too?
Matchstix
Oct 24, 2016, 3:36 PM
Same as the airshot it seems
Bizkit031
Oct 24, 2016, 3:42 PM
Yea this is not new airshot does the same and were the first.
fanievb
Oct 24, 2016, 4:53 PM
For R200 more you can buy a small compressor from adendorf
#justsaying
Skylark
Oct 24, 2016, 5:32 PM
In the article "Schwalbe is now launching the Tire Booster, which was developed in collaboration with the British start-up Airshot"
AlanD
Oct 24, 2016, 5:38 PM
Pretty cool and handy to have but a trip to the petrol station cost you nothing, ok, a tad bit of petrol but how often would you need to seat tyres anyways
bikebloke
Oct 24, 2016, 5:48 PM
they are trying to get us roadies to go tubeless because they got all the mtb crowd to go with it.
may go tubeless when the tubeless tires are closer to ordinary tires in price - right now it costs double for a tubeless road tire as compared to an ordinary one - they last just as long as one another and expense of all the stans and tape etc is about the same as a tube .
so its twice as expensive to run tubeless for the same mileage .
oh yeah and you may need new wheels too because all road wheelsets are not tubeless compatible.
and add the price of this new tire booster gadget- which you will use once or twice a year.
then consider what happens if you rip a tubeless road tire and it wont seal - do you want to try fit a tube (which you will carry anyway) in that monster non stretch bead thing on the road side ?
compare all this to really tiny marginal gains (you aren't going to run it soft for better traction this isn't CX) .......
and let me think ..which pros run tubeless again  ................ :ph34r:
its a gizmo with hype :whistling:
ill stick to tubes and your ordinary tires thanks schwalbe :thumbup:
V12man
Oct 24, 2016, 5:49 PM
One could Probably make one of these easily enough with a paintball cylinder and a few bits and some smarts
Matchstix
Oct 24, 2016, 6:47 PM
Fire extinguisher
Hairy
Oct 24, 2016, 8:29 PM
Only reallY struggled to mount two tyres before that I had to go to a petrol station and have a moment or two of humour failure ..... one was a 26er tyre and the other 650b. ....the common denominator though wad that they were both Hans Dampfs
lechatnoir
Oct 24, 2016, 8:57 PM
Scuba tanks hold 300bar or more... doubt this can reach that much, but probably can hold far more than even the best footpump can attain.
Matchstix
Oct 24, 2016, 9:21 PM
We have destroyed 2 floor pumps trying to pop a tubeless tire of a rim with a tube inside. . 11 bar plus. When the tire popped. . .
Sarge
Oct 25, 2016, 5:59 AM
Hi,
I am not a MacGyver type of person, so not into the home made gismo's. If this will make the seating of a new set of tyres easy, with little hassel...I'm in.
Regards
Sarge
rock
Oct 25, 2016, 7:16 AM
free.
http://adrianbriencars.com.au/blog/wp-content/uploads/2013/07/Tyre-Pressure-02-Web-Small.jpg
Sidewinder.
Oct 25, 2016, 7:59 AM
free.
And obviously mtb's never go anywhere there isn't a petrol station right? No mtber really likes getting away from city, really just a useless product.
rock
Oct 25, 2016, 9:05 AM
not sure where you are going, is this product meant to be carried in your pocket while out riding??
Sidewinder.
Oct 25, 2016, 9:27 AM
More like, say you are camping at trails far from town, or are at a stage race...or even if a tire dies on you during a race and you have spares in the car. Point being, I can see where it would be convenient. If you already have a compressor or the correct valve adaptor to make a mess at the garage, then don't buy it.
It's just annoying how the first response to any new product is negative on these sites.
Skylark
Oct 25, 2016, 9:28 AM
Very handy product price isn't so crazy considering bike industry prices.
rock
Oct 25, 2016, 9:46 AM
ok I get it now.
Hairy
Oct 25, 2016, 10:05 AM
wonder if they tested that under conditions similar to a nice and toasty SA summer where the user brings a charged unit to a race, leaves it in the car (No shade) and comes back later.
I would think the pressure in that will increase substantially .... is there a release / safety valve at all in the design of the unit?
Mongoose!
Oct 25, 2016, 10:20 AM
is it really that unsafe to make your own?
Even if you wrap the cylinder (2L plastic bottle) with duct tape to prevent it from shatter in possible explosion? :ph34r:
