Lezyne has been designing and manufacturing high-quality bicycle tools and accessories since 2007. It was founded by industry icon Micki Kozuschek who, not long before doing so, sold Truvativ to SRAM.
Lezyne’s goal was to engineer and produce premium quality accessories that meet the same high standards as high-end bicycle components. Several design awards show they have been successful.
Lezyne V Tool V-7
Lezyne V Tools are compact, low profile tools made with lightweight and durable materials. They feature CNC-machined aluminum side plates and the V10 and V11 features a forged and CNC-machined aluminum chain breaker for 9/10/11 speed chains. Chrome Vanadium bits and fastening hardware is durable and nickel plated. Forged, Center-Pivot bits increase tool rigidity and improve ergonomics.
Lezyne’s V Tool is also available in V11 ( Hex 2, 2.5, 3, 4, 5, 6, 8mm; Star Shaped T25, T30; Flat Head; Chain Breaker), V10 (Hex 2, 3, 4, 5, 6, 8mm; Star Shaped T25, T30; Phillips-Head; Chain Breaker) and V5 (Hex 3, 4, 5, 6mm; Phillips-Head) models to suit most needs.
Specification:
WEIGHT: 65g
DIMENSIONS: 32W × 63L × 19H (mm)
TOOL BITS:
Hex 2.5, 4, 5, 6mm
Flat Head
Lezyne Road Drive
The Lezyne Road Drive is a high pressure hand pump made entirely of aluminium for precise and lightweight construction. The barrel, handle, piston, end caps and pump mount are all custom CNC machined. The high pressure design makes this a frame pump replacement, easily inflating tyres to riding pressure with fewer strokes. It comes equipped with ABS Speed Flex Hose, which is a Presta only inflation system. One end of the hose is a threaded Presta valve connection with ABS, while the other side has Lezyne’s Slip Fit system for fast valve engagement.
Specification:
SMALL: 180mm | 82g
MAX: 160psi | 11bar
MANUAL: ABS Speed Flex Hose
The Road Drive is available in medium (216mm, 96g) and large (283mm, 110g) as well.
Lezyne Control Drive CO2
A compact, 100% CNC machined aluminum CO2 inflator. The Control Drive twist operation allows for easy and precise inflation. The Control Drive head slips directly onto Presta and Schrader valves and puts the rider in complete control over how much CO2 you discharge at a time. It is compatible with threaded CO2 cartridges only and comes with an anti-freeze jacket to protect your hands during inflation.
