Zipp 353 NSW is the first SRAM AXS connected wheel
Supplied by SRAM Communications Team.
Zipp’s 353 NSW is the first SRAM AXS connected wheel, offering in-wheel tire pressure monitoring on our most advanced and lightest rim design. Zipp’s 353 NSW Tubeless Disc brake is the pinnacle wheelset for today’s endurance rider and road racer.
353 NSW TUBELESS DISC BRAKE
Zipp’s most advanced wheelset in every performance area, the 353 NSW also is Zipp’s first SRAM AXS-connected wheelset. Designed for racers, it’s a lightweight climber’s wheel that comes with ceramic bearings and Zipp’s most advanced rim technology for impressive durability and aero performance. The 353 NSW rim seamlessly integrates the Zipp AXS Wheel Sensor for accurate on-bike tire-pressure monitoring. It allows you to monitor and analyze tire pressure in real-time without an external device mounted to the valve stem. Fine-tuning tire pressure helps riders optimize speed and performance in an ever-changing riding environment. Before you ride, check your pressure immediately; green light means good to go. During the ride, monitor pressure to dial in your ideal setting and detect issues early.
Strong just got stronger for Zipp’s lightest wheelset. A revised carbon layup and design infused the already strong 353 NSW with a more than 16 percent higher rim impact strength. With its undulating 35/40mm deep rim shape, the 353 NSW provides speed on the valley road, the mountain climb, and the descent with excellent rolling resistance, crosswind stability, and feather-light weight. The 353 NSW features the premium ZR1 SL hubset with ceramic bearings and 66 points of smooth rolling engagement. The hubset also is 30 g lighter than the predecessor hub in NSW wheels. The 353 NSW is optimized for 30mm tires, with great options available from Goodyear Fitment Series tires made exclusively for Zipp. The 353 NSW is not approved for gravel riding.
SPECIFICATIONS
  • Wheel size: 700c
  • Rim Construction: Tubeless Straight Side (TSS) hookless
  • Tire Compatibility: Tubeless Tire Only, option to run inner tubes with threaded valve
  • Rim Inside Width: 25 mm
  • Weight: 1,310 grams
FEATURES
  • Versatile endurance wheelset for the modern road bike with tubeless and hookless rim profile
  • First integrated, connected SRAM AXS wheel with Zipp AXS Wheel Sensor, with ability to monitor pressure with specially designed tube
  • ZR1 SL hubset with ceramic bearings
  • Optimized for 30mm tires
  • TSE for greater efficiency and reduced rolling resistance.
  • Sawtooth rim with Hyperfoil nodes and HexFin ABLC dimple pattern for top aero and crosswind-stability performance with an undulating rim depth.
  • Center locking rotor interface. Lockring is included with the wheels.
  • XDR or SRAM/Shimano driver bodies (Campagnolo driver body sold separately)
  • Lifetime Warranty
303 SW: Modern Classic
Zipp 303 SW offers performance on all roads with SRAM AXS-connected in-wheel tire pressure monitoring. Zipp’s 303 SW Tubeless Disc-brake wheelset offers superior speed on all roads, no matter the surface. Steeped in Zipp’s legacy of innovation, the 303 SW is a modern classic wheelset, fully capable of road, gravel, cobbles, and cyclocross riding.
303 SW TUBELESS DISC BRAKE
The 303 SW rim internally integrates the Zipp AXS Wheel Sensor for accurate on-bike tire-pressure monitoring. It allows you to monitor and analyze tire pressure in real-time without an external device mounted to the valve stem. Fine-tuning tire pressure helps riders optimize speed and performance in an ever-changing riding environment. Before you ride, check your pressure immediately; green light means good to go. During the ride, monitor pressure to dial in your ideal setting and detect issues early. The 303 SW’s 40mm deep rim design takes design cues from the gravel-specific 303 XPLR to utilize a wide rim design for high aero efficiency and low rolling resistance on a wide tire platform designed for modern riding at lower tire pressures. The rim’s profile provides low drag and an improved transition between rim and tire, boosting aerodynamic efficiency with wider tires.
The wide-rim stance also features less tire deflection for reduced rolling resistance. Combining the wider tire, increased tire volume, and lower tire pressure helps reduce rider fatigue by smoothing out the ride over imperfect pavement and road conditions—the tire and wheel system absorbs the shaking, not the rider. A revised carbon layup and design also infused the already bombproof 303 SW with an almost 10 percent improvement in impact strength at a light weight. The 303 SW is optimized for tires 30 to 35mm in width. The 303 SW rims feature a refined shape that helps shield the tire in an impact that would otherwise cause a pinch flat. At the center of this is the ZR1 hubset, which now has stainless steel bearings for improved durability and smoother performance.
SPECIFICATIONS
  • Wheel size: 700c
  • Rim Inside Width: 25mm
  • Weight: 1440 grams
FEATURES
  • Fully capable wheelset for modern road and multi-surface riders
  • First integrated, connected SRAM AXS wheel with Zipp AXS Wheel Sensor; ability to use sensor with compatible tube
  • ZR1 hubset with stainless steel bearings.
  • Optimized for 30 to 35mm tires
  • Center locking rotor interface. Lockring is included with wheels
  • Lifetime Warranty
